1 - 12 of 12 Posts
ok you know that noise that you hear while idling with a cold air intake installed??? its like a vacuum sucking noise??? and then when you shut the car off it makes an air release sound??
well my car was doing this, but the other night i was driving on freeway and when i got off the freeway my car just died... so i started it back up, it seemed fine and it hasn't died since, but now there is no intake noise at all.
what all of this rambling is about is i want to know if you guys think something is wrong with the car or if im just trippin...
ps...
the filter is still on the intake and I did not suck up any water...
sounds fine to me... you have just aluminum piping and a filter. your hearing the vacuum (correct me if im wrong) I have a short ram air. and makes the same.. the original is quiter because it's plastic tubing and thus insulates the noise more( right?)
your engine dieing... IDK.
Check your vacuum hoses and the intake mounting to the throttle body.
check all the valves on throttle bodty and back of intake mani. clean'm out.
1 - 12 of 12 Posts
