1 - 9 of 9 Posts
Retired From Hondas
Im wondering with all these header designs and alot of them with piping going all different directions, and some needing a condenser delete, Has anyone tried the do a ram horn like the FI manifolds?
My thinking is that if it flows great for a turbo, why wouldnt it flow just as good for mid to top end N/A? Then you would have a 2.5" sweep under the oil pan and have good ground clearance. You can use Vbands at the collector for simple removal of the pipe.
Maybe this has been posted before, but I havent seen anything on it.
Thoughts and Ideas?
Retired From Hondas
Kool ^^
I know I wasnt the only one who has thought about this.. Instead of a T3 flange, just a 2.5 Vband and a flex pipe somewhere inline.
Ill volunteer to be the first one to try it out and give back dyno results.
I have a 11.2:1 B20 P8R almost ready to drop in my bay and in the market for a header that will flow mid-high RPMs
As long as the runners are close, the exhaust pulse should be fine.
Greg, whatcha think?
91 Civic
i think the reason this inst very common is because your runners will be very short so it will give you no bottom end and its proably so short that the resonance would want to shift your power band to idk say 15k rpm
Retired From Hondas
i dont believe that at all.. theres plenty of high flowing headers on the market.
and the loss of torque thing is a myth imo
Exhaust scavenging is very real, fluid dynamics man. Its not a theory, its a fact. Whether or not its implementation in high-end long runner headers is noticeably beneficial im not sure, But I see no gains in creating what you speak of other than aesthetics.
Acura TL-P
The collector portion of what your referring to sounds like the old Kamikaze header. This style worked well on old Supercharged setups.
1 - 9 of 9 Posts
