Hey guys the title says it all. Radio will not turn on. I replaced it with another radio and still will not turn on. I've checked the fuse under the dash and its fine. The cigarette liter works fine as does the clock above the counsel. I noticed this problem after I replaced my heater core and had the dash out. Am I missing a ground cable for the radio that resides in the dash itself? Any help will be appreciated. If it makes any difference it's a 92 dx.
Thanks in advance
95 Honda Civic DX
Have you checked the hot wire with a test light or multimeter to see if it was getting power. If it is try running the radio's ground to a bolt on the chassis to be sure it's grounded.
Take the radio ground wire and ground it to the metal that's right under the radio.
90 crx si/96 accord
more like. take a test light to both the power wires from the harness to verify power....then use the radio ground wire from the harness to use as a ground. for the test light and re check for power to verify radio ground.......
