1 - 9 of 9 Posts
Yes i used the factory wiring. The will not work at all. At idle it works just fine but rev the motor or drive it past 2000 rmp it wont work.
FAMILY MEMBER #316
voltage regulator bad on your alternator?
pull the radio out and put a meter on the yellow wire going to the radio. measure voltage at idle and then as you go past 2000rpm.
1 - 9 of 9 Posts
