What other radiators will fit my 90 honda civic wagon fwd? Just 88 to 91 civics or will something from another car fit?
Discussion Starter · #2 ·
Nvm pulled a rad out of a 90s honda that was the same height but half the length. Its aluminum so I think it will probably be as good or better then the stock copper one
find the measurements you want, and go explore rock auto or google. some vw rads fit
Discussion Starter · #4 ·
I needed it today so nothing online. I went to the junkyard to find something I could make work, And yea there was a vw that had nearly the exact dimensions with the ports in about the same place. I opted for the aluminum one that was smaller tho. It looks like its gonna work but won't know for sure until i get the head back on
none of the 88-91 civic/crx radiators were half size, that was exclusive to 92-00 civics.
Looks like a prior owner of that vehicle did an engine swap and partially returned to stock, or found a radiator far cheaper, or whwatever reason.
Sorry, by 90's I ment the 92+ model civic. None of my local yards had any 88-91's and I needed the car done that day. Thats why I used the half sized one. Ive put 200~ miles on it so far with no problems
What about the 3/4 sized units in the EF's? Mostly HF CRX's and STD HB's
3/4? You mean the ones that have that extra 6 inches or so chopped off one side?
I thought those were always some sort of neutered aftermarket offering, not a factory setup.
