will a 92-95 radiator fit in my 97?..i know that ebay sells radiators that cover 92-00...this leads me to believe that the 92-95 radiator will bolt right up in my car. Does it matter if the car is auto or manual? (mines auto)...
68 Camaro
before you but an ebay one make sure it has the holes at the bottom for your a/t (im assuming civics have a/t coolers im not sure)
yeah auto and manual are diff I believe. but im pretty sure the manuals are the same for those years.
68 Camaro
pretty sure the one i put in my manual civic had the holes at the bottom for tranny cooler lines if im remembering right
so then...the radiators bolt up and the coolants hookups are the same other than the trans cooling lines which either could have and only one could use...so if they are on the new radiator i bought...all they have to be is capped off or connected depending on which transmission i have?...
did that make sense?
68 Camaro
i believe theyre the same part you just leave the holes plugged if you have a mt and you hook up your at lines if you have an at
