ok here is my problem just got my delsol back on the road built a y8 everything is great except while I was driving car started over heating pulled over water was gushing from radiator cracked on the top under filler neck so okay towed it home put another good radiator in drove it for 20 min an bam cracked near the mount WTF would cause this???
Is your rad support bent up and putting pressure on the radiator? Could be causing stress on the tank. Should be able to slightly wiggle the rad when properly mounted.
compression is good there is no back pressure entering into cooling system by the way of a HG i think it might be just a faulty radiator... Im going to by a go autoworks full alum and see if that helps
Related Threads
Honda D Series Forum
2.9M posts
63.5K members
Since 2003
