1 - 15 of 15 Posts
06 coupe
my buddys got a y7 in his 96 hatch and is needing a tb. he is putting on a z6 intake mani at the and it didnt come with a tb. i found him a h23 tb. will this work? thanks
06 coupe
try it ummmmmmmm no i aint buyin it then trying it if it isnt goin to fit.
Lurking... ಠ_ಠ In Your Thread
ES1 Civic
06 coupe
that works for me i guess i didnt know if h22 and h23 tbs where the same or not.
he said he has the Z6 manifold, so im sure he converted all that.
92 civic hatch si
Yeah b should work. I am running tb from b series on my z6. Plug and play
If he's running an OBD2 ecu, there is nothing to convert.
The engine is a Y7, so the stock ECU requires a 3-wire IACV. Even if you rewire, the ECU will not recognize the 2-wire IACV.
The only OBD2 ecu that would run a 2-wire IACV is the P2P, but then it would throw multiple codes on a y7 engine because it wold not be able to find a knock sensor, oil pressure sensor, and vtec solenoid.
The only way a B or an H throttle body would work on a Y7 is if he converted to a non-vtec OBD1, which he might have, it wasn't mentioned.
06 coupe
ok how about a complete GSR 95 throttle body complete with Fast idle
valve/TPS/map sensor and its inperfect working condition.
1 - 15 of 15 Posts
