1 - 7 of 7 Posts
So, I have distributor all the way in this direction, and its still out of time. Does anyone know which direction I have to adjust the cam gear?
No Tune No Life!
99 Supercharge Regal
So if i dont move the camgear, do i move the belt right or left 1 tooth?
you cant move the cam gear to change ignition timing with out changing cam timing.
AGAIN I ASK how are you checking your ignition timing and were is it at now.
i actually have no clue how to do it. I took it to a mechanic for timing. He said it was all the way adjusted, but he still didnt have enough.
slide belt off, turn CAM gear one tooth clockwise, reset dizzy to center of adjustment range and recheck ignition timing.
1 - 7 of 7 Posts
