1 - 3 of 3 Posts
Hey guys, i'm new to the forum. Just bought a 97ex for the lolo, and stuck in a mini me i had laying around. It's a d15b7 with z6 head. Would the lack of knock sensor in the block be causing it to bog badly and cut out at full throttle, or above 4grand. The car runs fine otherwise, just when you try to give it a lot of throttle. If anyone can think of anything else to check let me know. Thanks in advance.
I got Bit by the Boost Bug
Bmw 528e
I had that problem kinda on my old teg.. It ended up being timing after i replaced the dizzy,plugs,wires and fuel filter, so check all those is all i can tell you from my experience bro....Hope you get it figured out....
thanks for the help. I know it's at tdc cuz i've checked it about 9trillion times. I'm running the obd2 ecu, and stock ex harness. Just wondering if the other sensors not being plugged in such as the injector sensor thingy (don't know what it does) may have something to do with it. Any more suggestions?
1 - 3 of 3 Posts
