1 - 3 of 3 Posts
i have a d16z6 block n i have some 75.5 vitara pistons n an old set of eagle rods from my ls b18b1 .....can i use those rods on my d16z6
same
Some machining will need to be done to make them fit as they are wider but they should be fine. You'll just have really low comp with this setup. Good for high boost. Roughly 7.5:1 according to zeal. The compression height for vitaras is only 28.50 mm with a 15 cc dish and stock p28's ( z6) run a 30 mm comp height with a 10 cc dish so you go from 9.1:1 down to 7.5:1. But ya you need to narrow the connecting rods as they are too wide at the crank if I'm correct.
1 - 3 of 3 Posts
