Lol dryer hose IC couplers FTW! Why not just use silicone couplers like you have in the picture?
I think technically it would "work", but thats gonna hurt your flow.
hahah its steel but same looks the same. I would use a 908 steel elbow but its a bad angle. and needs some flex in it. thought of silicone also but still might not be able to make the angle.
I guess ill jsut have to find something else. OR what if i use only a small part of it . just need it to point down then ill weld it all up in steel. would that still hut the flow if i used like 6inchs or it?
no room. If i move it towards the condenser it will hit and not have space. If i move it more up the wastegate wont work, too much of an angle.
So kinda gotta leave it where it lays.
My old gr17 setup was a pain to setup.....but you can clock the turbo.....you will have to customize the wastegate ARM, that's why they can adjust in the middle of the ARM....I had too bend my rod at about a 35-45* angle.....it worked very well....I sold it to 90civichillclimber who also had no issues with it
you can see how i had to bend the actuator arm to work with it clocked
torque mount trimed to fit
here you can kinda see my old t28 setup.....i clocked the turbo which was facing strait up to point down attached the w/g bracket to the right spot but as you can see i just threaded a bolt to keep the w/g flapper held shut and went external w/g
@ hb it cool.
@scotth thanx . Mines is a little bit harder since the wastegate mountd under the outlet.
Im going to clock it today and see what i can made for a mount. will post back ideas.
Nice work....I know I bought a fitting on eBay so you can run a filter.....If I were you I would still use it and notch the flange on the adapter to sill use your wastgate like that
