Live,love,laugh,be real
96' Accord Wagon
just need clarification
in all the info i have found it seems like you adjust the intake and exhaust at the same time... is this correct..?
if it is, how does it make sense when it's two different stroke's; ie, intake stroke-exhaust stroke..?
'91 CRX Si
set #1 to tdc. set both intake and exhaust valve clearance (.007in/.009ex)
rotate crank 180*
set #3 both intake and exhaust
rotate crank 180*
set #4
rotate 180*
set #2
at least that how it works on the d-series, im assuming b is the same!
edit: rotating crank 180* turns cam 90* just a little FYI
96' Accord Wagon
thank you, i understand the rotation, just wanted to be sure if you set both intake and exhaust at the same time... just doesnt sound right to me...
BTW it's:
in. .003-.005
ex. .006-.008
this is for 92-93 B18a1
I also have a cool title
I did both in and ext at the same time on my b18c1. started at cyl1 down to 4 making sure i was at TDC for each cyl i was adjusting the In and ext on.
'91 CRX Si
BTW it's:
in. .003-.005
ex. .006-.008
word, i was just spouting off the d-series way!!!
never set clearances on a b, that is good to know though!!
When you are setting the clearances with each cylinder (according to the cams) at tdc all 4 valves are closed does that make sense??
honda/firebird form.
correcto. and if they arent, your cars mechanical timing is off
96' Accord Wagon
deos it make sense to me... NO lol but this is why asked you guys :)
thank you for all the quick replys, i will rep who ever i can... :td:
96' Accord Wagon
i got it all done, took all of an hour to do...
most were loose, a few were tight, one was just right...
needless to say, it really needed it...
