1 - 3 of 3 Posts
I recently had a header and exhaust installed on my 98 DX Coupe.
I noticed the Oxygen sensor at the end of the header is not plugged in to anything.
I also notice a plug next to the upper sensor that is not plugged in to anything.
Logic says they should go together but I want to be sure.
Anyone know the colors of the plug from the ecu to the lower oxygen sensor?
The car ran great for a month but now when it gets warm it feels like it's running out of gas.
If I let it cool it is good for another 10 mins or so.
I just put an aluminum radiator because the old cap wasn't tightening and the radiator was old.
I also just did Cap and Rotor and an oil change. I haven't driven it since the day those problems happened 2 weeks ago.
I basically want to know where to hook up the lower oxygen sensor and what problems would come from a disconnected oxygen sensor.
TIA
I was throwing a code before the exhaust and header but it was very once in a while and a removing the battery cable took the light off for weeks.
The code was Rich/Lean running engine.
I was expecting a check engine light because I have no cat so I took the light out of the new JDM cluster with Tach I just installed so I can't tell the new code.
The sensor isn't conected so I know one of the codes is that.
Dan
1 - 3 of 3 Posts
