1 - 6 of 6 Posts
R
Ok, i got a y7 and want to put in a y8 head, many people have told me to get a y8 intake manifold, but is that really necessary? some people say that if you use a vtec controller, you can reuse your throttle body but im not sure if i can reuse the y7 intake manifold. anyone know? thanks
D
Any TB in the d-series is the same 56mm. The y8 will have larger runners. You'll need the FPR from the y8. You'll need a vtec ecu unless you're just gonna run lean"er" in vtec w/ a controller. I would suggest using the y8 intake mani., I noticed a dif. with a vtec mani versus non on a non-vtec head. But yes, if you have too.
yah do the IM swap while your at it. y8 im is MUCH better over the y7. just fyi you can use your y7 fpr.
D
I just had problems running too lean with a b7 vs a z6. You probably are right.
1 - 6 of 6 Posts
