1 - 3 of 3 Posts
The timing light I have has an adjustable setting on the back of the gun. When setting ignition timing to 16degrees, should I have the gun set at 0 or 16 degrees?
Motor is a D16A6. Trying to set timing back to OEM specs.
Thanks!
92 civic hatch back
timing should be set to whatever the specs are for the d16a6, if its 16 btdc, set gun to 16 degrees. this has probably been covered before, do a quick little search before posting.
set gun at zero, center of the three marks on the crank pulley should line up, adjust dizzy as needed.
set light to 16, verify TDC mark on crank pulley
1 - 3 of 3 Posts
