1 - 7 of 7 Posts
Ok, so I'm considering using a Bullseye turbo for my Y8 vitara build. Who here uses one? How does it spool? Which one are you using? I'm shooting for maybe 350whp and I need something that will give a fairly broad powerband. Thanks in advance guys.
Lifes short, drive fast!
I have almost the exact biuld going on as you have plans. Vitara/eagle z6, shooting for between 320-350whp (look to sig for build thread). I have the bullseye 50 trim .55a/r. Full spool at around 4k, the .55a/r will give you the topend power of a .63 while giving a slightly lower spool.
Greg(go-autoworks) recommended this turbo over anything else for my setup, I would highly sudgest it for you aswell :bigok:
Go over to Honda-Tech or TurboD16.com and pm my son, rota92. He can answer your questions and hook you up with "Turbodano" at Bullseye.
I would suggest the 50 trim (.55 or .70) for your setup as well, pretty similar to Max713s.
We keep a small variety on hand, pretty much an inventory specifically for D series applications.
1 - 7 of 7 Posts
