1 - 7 of 7 Posts
Hello. Does anyone know if an EG steering column linkage / u joint is interchangable with an EF's? Thank in advanced.
Find ppictures, count splines.
They changed based on specific year, even within the generation, and changed based on whether the rack was power or manual.
Best way is to find your OEM number for the joint, and compare a real picture of it to whatever its planned on going into.
Slo/Will found out there were a lot of differences between accord, civic, and integra as well.
Reactions: slo_eg8
is it JUST the joint? or did you swap in a column/rack?
Vehicle Fitment
MakeBody & TrimEngine & Transmission
1991 Honda CRXBase, HF, Si1.5L L4 - Gas, 1.6L L4 - Gas
1991 Honda CivicBase, DX, EX, LX, RT 4WD, Si1.5L L4 - Gas, 1.6L L4 - Gas
1990 Honda CRXBase, HF, Si1.5L L4 - Gas, 1.6L L4 - Gas
1990 Honda CivicBase, DX, EX, LX, RT 4WD, Si1.5L L4 - Gas, 1.6L L4 - Gas
1989 Honda CRXBase, HF, Si1.5L L4 - Gas, 1.6L L4 - Gas
1989 Honda CivicBase, DX, LX, RT 4WD, Si, Wagovan1.5L L4 - Gas, 1.6L L4 - Gas
1988 Honda CRXDX, HF, Si1.5L L4 - Gas, 1.6L L4 - Gas
1988 Honda CivicBase, DX, LX, RT 4WD, Wagovan1.5L L4 - Gas, 1.6L L4 - Gas
lets go with NO
2000 Honda CivicCX1.6L L4 - Gas
1999 Honda CivicCX, EX1.6L L4 - Gas
1998 Honda CivicCX1.6L L4 - Gas
1997 Honda CivicCX, DX1.6L L4 - Gas
1997 Honda Civic del SolS1.6L L4 - Gas
1996 Honda CivicCX, DX1.6L L4 - Gas
1996 Honda Civic del SolS1.6L L4 - Gas
1995 Honda CivicCX, DX, EX, LX, Si, VX1.5L L4 - Gas, 1.6L L4 - Gas
1995 Honda Civic del SolS, Si1.5L L4 - Gas, 1.6L L4 - Gas
1994 Honda CivicCX, DX, EX, LX, Si, VX1.5L L4 - Gas, 1.6L L4 - Gas
1994 Honda Civic del SolS, Si1.5L L4 - Gas, 1.6L L4 - Gas
1993 Honda Accord10th Anniversary, DX, EX, LX, SE2.2L L4 - Gas
1993 Honda CivicCX, DX, EX, LX, Si, VX1.5L L4 - Gas, 1.6L L4 - Gas
1993 Honda Civic del SolS, Si1.5L L4 - Gas, 1.6L L4 - Gas
1992 Honda AccordDX, EX, LX2.2L L4 - Gas
1992 Honda CivicCX, DX, EX, LX, Si, VX1.5L L4 - Gas, 1.6L L4 - Gas
1991 Honda AccordDX, EX, LX, SE2.2L L4 - Gas
1990 Honda AccordDX, EX, LX2.2L L4 - Gas
1989 Honda AccordDX, LX, LXi, SEi2.0L L4 - Gas
1988 Honda AccordDX, LX, LXi2.0L L4 - Gas
1987 Honda AccordDX, LX, LXi2.0L L4 - Gas
1986 Honda AccordDX, LX, LXi2.0L L4 - Gas
Discussion Starter · #4 ·
According to hondapartsnow the joints are not compatible. The only reason I'm not 100 percent convinced is because of how similar they are. Additionally, there's an aftermarket u joint for lifted 1988-2000 civics that would imply that they are similar spline counts.
My local junkyard has plenty of 1992-2000 civics. I'm gonna go grab one and update for anyone else that has this specific situation happen for them. Also it's a power steering rack. :)
Like I said, power steering and manual steering also change this joint. Likely, the manual rack joint will work. Just need to figure out the difference.
I used to have multiple joints that Slo got for me when I was trying to do an EK project that never saw completion, if I did, I could at least get you emasurements.
Best bet is to run to the junkyard and spend $5-10 each joint and consider it "education" costs of figuring it out.
the reason theyre not, the shaft diameters are different. went through this in the yard when I sourced the parts for matt
Honda D Series Forum
1 - 7 of 7 Posts
