1 - 6 of 6 Posts
M
im sure that this info is some where on here, but ive been on here for more than an hour and cant find what i need.
Will the stock distributor retard enough for a boosted y7 on 9psi(W/ safcII)? or do i need a aftermarket system?
thanks
D-Series Post Be-itch... gimme gimme gimme
that will be controlled by your safc I guess... I know with crome, you can do step-retarding... never used safc.
the short answer, it is up to your fuel management unit...
W
yea depends on the boost because if it like....7psi or 9psi you should be alright. thats only like 7 deg. retard depending on car
M
whats the max retard you can get out of a stock distibutor? so i know that the safc will advance it so am i going to have to retard it more to make up for it?
if your running the "hack" like me (safc and dsm450 injectors) then retard the timing at the distributor 4*. this makes off boost driving a little sluggish but hey its the "hack" dont expect perfection.. plus its worked on my boosted y7 setup for 20,000 miles ..
later.
1 - 6 of 6 Posts
