1 - 20 of 33 Posts
i have a d16z6 block and i want to use p29 pistons. would i have any clearance problems with having a y8 head on there? if so any suggestions on which ones to use. i want to keep my cr under 13. i will be using akmee valvetrain kit with some new valves. thanks in advance...
im pretty much wondering the same thing man.
got a Y7 and might be doing the y8head swap and throwing in the p29s
yea i like that idea cause you can still run stock rods with some arp rod bolts and be ok..but im wondering if the pistons will knock the head?
FF Misfit
Accord
You'll be fine w/ the P29's.
SEARCH!!!!!
racist-bigot-sexist-homophob
Clay If In Doubt!!!!
why go arias? this isnt an all out build...i just need pistons to boost up the cr...
Because they can make any CR you want.... OMG ... noobs
No worries
The Great Weldini
91 civic
well if yu get aftermarket pistons you cant use the stock rods. i would like to be able to keep the rods because that is extra money i dont have to spend! thats why i was thinking of using the p29's.
FF Misfit
Accord
If you're just doing a DD that you don't plan to spray, P29's will work fine and you'll be able to keep your stock rods as well.
Why couldnt you use stock rods???? Who told you that Bull????
FF Misfit
Accord
He probably heard it from some other noob who has no idea what they're talking about.
Or on H-T
FF Misfit
Accord
Indeed. H-T says many things that are far from being true.
I'm running p29s with a y8 head in mine a long with MANY other people. You won't have any clearance issues.
1 - 20 of 33 Posts
