1 - 17 of 17 Posts
97 Civic
hey everyone well after a long winter i took out my car today for a test drive and notice that my wideband AEM was ready lean at idle 14.0-16.5 or so.
Driving it was readying around 12-13.5
Now could my car be running lean because i have two oil catch cans, one for the block and another for the head?? or could it be cuz the fuel had been sitting in the tank since october.
I have a 97 civic coupe d16y8 turbo
97 Civic
i didn't run it at WOT cuz the car was running really bad at idle, didn't want to damage anything
i always let the tank get nearly empty and then add a gallon or two of 110 before i put her up for winter......has always worked well for me
Sl2,Cx Hatch
sensor going bad? I let my car sit for 3months then i drove it the other day on the same tank of 93, AF was Spot on.
AFR change might be due to weather, higher or lower IAT's... if the tune isnt 100% perfect (which NONE are) then you will see some variance in different seasons
also your sensor could be reading off.
the catch cans may be your problem. it depends how u installed them. take a lot of detailed clear pics and ill let you know whats up
97 Civic
ok i check all vacuum lines, drain the old gas and fill it with new gas. It run a lot better not as just popping/backfiring from the exhaust but i still notice that it run a bit lean.
But this time i did the WOT and about 4rpms i got boost cut. this are the new readings.
idle 13.8 - 16.9
driving 12.9 - 13.5
WOT 10.0
doesnt look like you have anything from the intake manifold hooked up to the catch can, so i dont think the catch cans are the source of the change in tune
i think its probably weather related and tune related. but might be the sensor itself starting to fail or maybe a change in fuel blend.
check for vacuum leaks.
97 Civic
umm no i don't think a bad injector because my car would of been misfiring which is not
1 - 17 of 17 Posts
