I have been searching for awhile on hooking up a catch can and i haven't been able to find the answer yet.
Where do you hook up the vacum source on off the catch can when you aren't running a pre-turbo intake pipe?? Also, will teeing off the valve cover vent with the PCV line?? This is my plan but i don't know where to run the other line??
I dont know if this will help? I went from my valve cover to a pvc valve into my intake manifold. Then from the motor to the catch can in one hole and a mini filter in the other....
i just vent mine to atmosphere
you don't want a vaccum on your catch can - NA you can route it back to the intake but not turbo unless you have a check valve in there to prevent boost from charging up your catch can
just ditch the catch can and run a breather on the tee'd line.
mount the breather away from where it'd be a fire hazard.
