1 - 20 of 24 Posts
B
Hey Red,
Do you have the gear ratio's for the 1-5 of CRX Si and the ZC laying around?
All I see on the tranny page is for the 92 and ^ boxes. I would like to included these for the sticky up top.
Second, when slapping a hybrid cable tranny together do I use the forks that correspond with the case I am using or the gears? Or better yet, do you have a write up on assembling a hybrid cable trans I can link to the sticky? I keep searching but to no avail.
Thanks
B
kick ass. Thank you noob iaincrx Awesome reply, good rep for you. And Thank you as well Bone.
i just pulled two trannys apart and this is what i got, first column input shaft teeth, output shaft teeth and the ratio.... the trannys i pulled was the S20 and the S3T.
S20
12 - 39 - 3.250
20 - 38 - 1.900
28 - 35 - 1.250
33 - 30 - 0.909
36 - 27 - 0.750
FD - Shaft 16 , ring gear 68 - 4.25
S3T
13 - 42 - 3.230
22 - 42 - 1.909
28 - 35 - 1.250
32 - 30 - 0.937
36 - 27 - 0.750
FD - Shaft 17, ring gear 69 - 4.058
the s20 box i got from singapore. and s3t is from my car which is a thaispec b15 (similar to d15). the trannys look alike but the s3t is a cable clutch. So i wanted to reuse the s3t. What i did was use the the fd shaft and ring gear on my tranny with the s3t full gear set. I had to swap the spool as the s3t has smaller spool bearings. Also had to swap a few parts within the gearsets.
just wanted to add this info
domnic said:
S20
12 - 39 - 3.250
20 - 38 - 1.900
28 - 35 - 1.250
33 - 30 - 0.909
36 - 27 - 0.750
just a thought.. i heard that 3rd and 4th gears are interchange. is it possible to say.. use the 3rd gear (28 tooth) with the 4th gear (30 tooth) to get a 1.071 ratio?? :noway:
no way possible.
But you canuse the 1.066 from a 92-95 CX/VX for 4th gear with a little grinding.
transzex said:
no way possible.
any advise on where and how much to grind for the CX/VX 3rd gear to fit in as a 4th gear for the S20 tranny??
garilee said:
yupz.. the CX/VX 3rd gear (1.066) is perfect as a 4th for my S20 built tranny. Was wondering how it can be mod to fit in..
What I think Bone ment, is that you should look at your original 4th gear first, to see how much you need to take out of the VX 3rd.
uh.. i see.. thanks alot. Will update again abt how much needs to be grinded when i get my hands on the tranny:TU:
97 honda coupe
How about this setup? if you had all the gears from the different trannys, (you would need zc,crx si and crx/civic dx gears)
L3 cable si tranny 1st 2nd 3rd 4th 5th
zc/si1st zc2nd zc3rd dx4th si5th this would equal..
3.250 1.944 1.346 1.259 0.771
Whatcha think? too little of rpm drop?
1996 Civic Type DX
No. It worked great for what I built it for, which was a few trips down the 1/4 with a stock Y7. Would have been worthless on a road course or the strip with any more power.
Ep3, Denali XL, Ed9
rise from the dead...hehe
ive been searching but usually i find info on hybrid hydro trannys...and i got a cable
so does cable zc gears neccesarily mean jdm transmissions or they can be from 86-89 usdm integras?
i would like to learn what i can use to make a hybrid cable tranny for my crx using usdm parts. so i can go to the junkyard and get em
here are some links.....
remoer's hybrid trans threads...
http://www.d-series.org/forums/showcase/121082-my-build-reliability-my-d-i-y-all-time-thread-car-1-a.html
http://www.d-series.org/forums/showcase/123045-one-sexies-oem-parts-honda.html
they stickys touch this a bit too...
gearing from L3 tranys.. (interchangable with eachother)
L3 88-91 HF 3.250 1.650 1.033 0.823 0.694 2.954 FD(3.250 Cali)3.880
L3 88-91 DX 3.250 1.894 1.259 0.937 0.771 3.153 FD 3.880
L3 88-91 Si 3.250 1.894 1.259 0.937 0.771 3.153 FD 4.25
L3 JDM Integra ZXi 3.250 1.894 1.346 1.033 0.771 3.153 FD 4.437
L3 JDM DOHC ZC 3.250 1.944 1.250 0.909 0.878 3.153 FD 3.880
L3 is the cable trans code for 88-91 civics. HF,DX,SI you will find in your junkyard easy... the ZC 3-4 gears people are refering to are from the DOHC ZC trans. 87 and earlyer tranys are diffrent.
1 - 20 of 24 Posts
