1 - 7 of 7 Posts
T
I currently have a DEL SOL S, with a D15 SOHC engine... It has multi port stock and 5 speed transmission, well my question.. if i buy... this...
http://cgi.ebay.com/ebaymotors/JDM-Honda-ZC-DOHC-Civic-Engine-NO-RESERVE_W0QQitemZ7997616233QQcategoryZ33615QQrdZ1QQcmdZViewItem
what additional stuff would i need? would my injection bolt up, starter, altenator? dont have AC... computer? would dizzy be compatible.. .Any help would be great, thanks
note* its 4 am, had to go through and edit grammar lol
This one's for you, Duck.
Wait, what?
Well i'm no expert on the civic ZCs being swapped, but you'd at least need an ECU for sure. It looks like that one comes with a dizzy, but you may want to ask him. I think the only tranny that will bolt up is the CG trany, but I could be 100% wrong.
That price seems a little on the high side since the civic ZCs seem to be much more attainable than the integra ZCs.
Lifetime Awesome Member
'89 CRX HF
i believe that motor is a obd0 zc. you are obd1. so you will need a zc compatible obd1 dizzy. i do not know if the sohc and dohc are interchangeable. you will need obd1 240cc injectors, and an ecu that will have the correct fuel maps for it as well.
T
some of you say it works some say it doesnt some say i need some things some say i dont, does anyone know for sure? if i buy a DOHC ZC 1.6 liter, ODB1 what will i need?
Donkey
if its OBD1, the whole lot will run. No worries. And your clutch/flywheel from your D15 will work. Your ecu will run the engine fine, but you wont have the 7500 rpm limit or the proper fuel maps to run the beast.
BUT: If its pre-obd (obd0 like mine.....dont ask...) you will need the ecu that ran it, usually a PM7 or similar, and a whole lot of patience to re wire the whole thing.
This is my second time installing a D16a8 (ZC) from an 88 EF crx into a 92 EG hatch. It works.
My build:
D15B7 Transmission, flywheel and clutch
D16A8 JDM CRX Si engine with obd0 sensors (firewall map ect)
D16Y1 VTEC engine harness
PM7 ECU obd0 on rewired obd1 harness
works pretty good and slaps a few faces when i tell people its not a real Si. Just look at the cam position sensor on the head....LOL
have fun, and keep us posted
1 - 7 of 7 Posts
