1 - 3 of 3 Posts
01 Ford Focus SE
I have a D16Z6 and I was wondering what size tap to use to clean out the threads for the head bolts? Also does that size work on all d-series engines?
93 Legend L Coupe.
Make sure you get a "bottoming tap" for blind holes to get as much of the threads as you can. Just be VERY carefull you are starting these kind of taps in the head, as if you get it started wrong, you will have to probably have a machine shop put in an insert.
1 - 3 of 3 Posts
