i have d16z6 i have
Crower turbo cam
Titanium springs and retainers
blox block guard
Eagle h beam rods
acl race bearings
Greddy 14g turbo
Greddy fmic
Greddy turbo sp exhaust
Cat delete pipe
Centerforce dual friction clutch
Greddy fuel mgmt (blue) box
D15 transmission
im thinking buy vitara pistons 75.5mm
what size injectors do i need 2 buy ?
do u guys think i need biger turbo because vitara pistons ?
do i need to get another tune setup or greedy fuel mgmt box is ok ?
thanks for the help
Poop Sock
wrx & slut rex
i have d16z6 i have
Crower turbo cam
blox block guard
Eagle h beam rods
acl race bearings
Greddy 14g turbo
Greddy fmic
Cat delete pipe
D15 transmission
thanks for the help
well....... with a little bitty 14g you dont really need vitaras or rods because you wont really be making enough power to need them. look for a 15g or a 16g turbo. go ahead and use either rc 440cc injectors or the dsm 450cc's. that way you'll have room to upgrade just in case the boost bug bites you. it always does.... dont use the "greddy fuel management box" get a real tune. oh and loose the block guard.
Welcome to The D. start looking at other turbo set up's on here, that should help you a lot. go look through the "Showcase" forum.
93 integra ls b18c
or evo injectors if you can find them for a good price, also if you already have eagles just go forged pistons, that or sell the rods and get the fjt i-beam vitara combo
like wizard said turbo can be small just depends on what you are setting up for and how much power you want.
real tune, possible better tranny
yea i have eagle rods u think its not good w/vitara
i did not wana spend 500 on wiesco or cp more if that the best for u guys know more then i do
racist-bigot-sexist-homophob
If the bottom end is built then go with a bigger turbo.
