01 Ford Focus SE
I have a 93 del Sol Si and I was wondering what all has to be done to remove the P/S. I heard all you have to do when you remove the P/S pump is on the rack you have to loop the 2 lines that come off it (the high and low pressure lines) and put like a breather valve between them. If anyone knows the way to do it please let me know. Thanks.
the lines are different size, so getting a fitting that doesn't leak is a PITA. I'm swapping on a whole non power rack on a 94 Sol Si this weekend, along with other suspension upgrades. I do know you can run the rack dry and it won't hurt it, then loop the lines.
Team Sol should have a article by Slater..........
swap the subframe and rack, yank the lines and pump, really easier that trying to get at the lines.
01 Ford Focus SE
is the rack fixed to the subframe or is the subframe just set up different for the non P/S del sol's?
01 Ford Focus SE
i see. i am probably going to look into swaping my rack and subframe. thanks for all of the help.
if you need help, your not far from Detroit.........the rack/subframe swap was one of the easy items this weekend!
