1 - 4 of 4 Posts
this motor is a b7/z6 i know you have to use a y8 cam gear to compensate for the differance in deck height but im confused on how to set the timing using the y8 gear do you just put the lines parallel with the head or is there something stupid you have to do cause with a z6 you use the bottom line and the pointer on the back cam cover any info would appriciated
oh yeah and i did search but couldnt find an answer to this
1 - 4 of 4 Posts
