1 - 9 of 9 Posts
1994 EH9
#1 : Can I use a D16Z6 head gasket (3 layer steel) on my D16A6 head and block...(boosting it!)
#2 : Can I use a D16Z6 head gasket set on my D16A6 (will all gaskets fit??), something like this:
http://cgi.ebay.com/ebaymotors/92-95-HONDA-CIVIC-DEL-SOL-SI-VTEC-HEAD-GASKET-SET-D16Z6_W0QQitemZ160201674988QQcmdZViewItem?hash=item160201674988
#3: Can I use a D16Z6 ARP Head Studs on a D16A6.
Thank you
ok,the z6 and a6 are pretty similar,both having the same bore,stroke,etc. im not a 100% sure but i think you can use each one one the other. But here is my question to you,if your gonna be "boosting it!" then why dont you get a comestic gasket or felpro? And you can use z6 headstuds on the a6
I can't read...
2myHonda1>is that cometic hg a oem or a metal one? ..or does cometic only manufacture metal ones?
1 - 9 of 9 Posts
