1 - 16 of 16 Posts
I
I've searched and found that You can use the ECU of a USDM D16 for a JDM D15B VTEC Swap. If my cut off is around 6800 rpm, does that mean that I have the USDM ECU for the D16. I've read that I can take it to 7200 rpm.
Sorry if this is a noob question, but i'm new to d's. I just bought this 94 civic coupe and it came with the swap. Just trying to figure out was up with the ECU.
D
A p28, usdm d16 vtec ecu, should have a limit of 7200rpm. Sounds like you've got a dx ecu, p06. You know you're getting vtec? What is the code on the side of your ecu?
DX ECU = 6500 rpm limiter, 6800 on the stock tachj
EX ECU with CEL = 6800 rpm limiter, 7100 on the stock tach
EX ECU running right, 7200 limiter, 7500-7600 on the stock tach
EX ECU using Crome Pro, hi cam disabled, 7500 limiter, 7900 on the factory tach.........
it means you have an auto ecu
I
Do I need to change the ECU to a manaul ECU or can I do something to make it work right without changing it?
W
/\ changing a ecu to manual is no easy task
I
I've searched and I found that a02 ecus are manual, i'll assume that a02 is also. No one nows?
I
nah I checked, I got a manual according to the above link.
No more Honda's :-(
Civic CX
what are you reading that says 6800? don't forget the stock cluster's are ussally way off.
Ecu
What up D-series. I got my hands on some info about changing a P28 ECU that was meant for auto to make 5-speed. You might get fluctuating idle that will drive you CRAZY once the car has warmed up. What you do is, open it up and de-solder the RP17 and RP18 resistors. When you do, it will stop. You also might throw the code for auto-tranny lock-up before doing that, but if you're not throwing codes, I wouldn't mess with the ECU. P08's a hard find, and most want a grip for them. If you're lucky enough to know someone with one, see if you can put it in yours and see if you get your rpms.
1 - 16 of 16 Posts
