1 - 3 of 3 Posts
Hi, I am new to this site, and new to cars. I have a 1995 civic EX. I just bought and I have some trouble.
The car, I have gotten does NOT have timing belt cover. The timing belt is exposed as well as the cam sprocket. When I turn on the engine, the timing belt will slip out of the sprocket teeth a bit. Meaning that the timing belt would move to the right side a bit.
Is there a possibility the timing belt would fly off and destroy my head? or is it fine?
95 EG coupe
beleive it or not..... its fine the same thing ur seeing without the cover is happening if the was on its not good to have the cover on due to dust and debree but ur fine
See above...
You're talking about just the upper cover...correct? I've ran my hatch for about 2 years w/o the upper. But you say the belt starts to "slip" off the cam pulley a bit? I'd check into the tensioner.
1 - 3 of 3 Posts
