i just ordered the set of three. i'm assuming that these are the 3 lower and i still need to get the upper, where the timing belt is? if i do the top mount, do i need to do that when i change the timing belt, or can i do it anytime?
btw i have a 97 ex mt
thanks,
james.
I done this procedure twice on 92-95 civic (mine and a friend's)
Included is the tranny inserts (rear one)
Engine mount (driver side 4 pieces u will use 3)
Tranny mount pass side (2 pieces)
lower support mounts are not included, IMO no need to swap those
Edit: you do not need to remove the timing belt... just unbolt the whole mount from the block using impact gun
i was thinking the inserts replaced the rubber part in the mount. if i have a broken mount, do i need to buy a new one?
thanks,
james.
