G
·i have an 88 crx si and the car hesitates/bucks under load in any gear when i give it some throttle. when the engine bucks, the check engine light comes on. i switch gears to a low rpm and the bucking stops and the check engine light turns off. my ecu is flashing code 13 wich is atmospheric pressure. i already checked the map sensor and thats ok. im beginning to wonder if its the coil/ignitor, or some part of the fuel system. i really need some help as soon as possible. thanks
