i have a d16z6 with eagle rods and vitara pistons. Installed turbo kit last weekend and it blew a head gasket running 8lbs. replaced the gasket, car wont start no compression in cylinder 1 or 2. any one have ideas why? there was water in cylinder 1 aND 2. the block looked completely fine when the head was off. the other cylinders have compression. any help would be much appreicated
i agree with the leak down test. it seems like your head or block possibly warped, or your valves arent seating and leaking compression.
arp bolts. the head isnt warped. i think my injectors were at 110 duty cycle
Did not see that you were using stock injectors. You probably burnt out the cylinder or some valves. Leak down test will tell the story. And y boost on stock injectors? Hell you could of capped the injectors at 80% and ran a small fmu. 110 is over kill. 80 should be max.
So leak down test. Its more or less rings or burnt valves
