1 - 3 of 3 Posts
91 civic dx hatch
car is throwing code 16 (injectors) but jerking around a bit during cruising speed/partial throttle as if the tps is bad.
i've already replaced the injectors and tps, still same problem.
the car does not hestitate/jerk upon full throttle, only partial.
any idea's for what to check/replace now?
im guessing its another sensor... ?
maybe something with ignition system?
are you still dpfi(shitty 90hp 2 injector clown show) or have you converted to mpfi and if so what ecu are you using?
1 - 3 of 3 Posts
