1 - 9 of 9 Posts
I recently installed a chipped P75 ECU and 450cc injectors and the resistor box in my d16y7 turbo. The problem is that when the car is on idle, the AFR reads 19-20 and the idling jumps from 1000 rpms to 1500 constantly like if the car was on limp mode. Also, the CEL turns on. Can I check the CEL codes through the OBD2 connector even though I have a OBD1 ECU with an engine harness converter from obd2 to obd1?
Some issues/Information:
Car takes a while longer to start as usual
The ECU is setup for the 450cc injectors and running a basemap
Only when the car is running in boost is when the AFR reads rich and maintains
The FPR is currently at 60 psi when I had it before on 42-45 psi.
(Car wouldnt start until I raised the fuel pressure)
I already have a Walbro fuel pump installed
definitely sounds like a problem with the tune, ive had that happen when using different base codes, or not having certain things disabled.
youll get more help if you list what program your running; who, what its tuned on...
basemaps are ONLY for starting a vehicle to check for leaks and prep for a tune, NOT to be driven around. get the car tuned, there is no reason to raise your fuel pressure that high.
get the car tuned.
get the car tuned.
ahhhh yes i missed that.... theres your answer bud.
there is a connector in the pass side by the ecu. It should be blue with 2 pins. Your have to jump that to get the check engine light to blink to tell u the code.
►►THE Check Engine Light (CEL) THREAD: HOW TO & CODES◄◄ - Honda-Tech
find that out then report back. and x2 on not driving on a base map. Also dont up the fuel psi because that will throw off the whole map.
Alright, I will go get the car tuned but will check the CEL code and post the results here.
I actually thought that I could actually run the car with the basemap. Also, I got the ECU chipped and the basemap from Xenocron.
I have another problem, I located the service conector and inserted a loop connector with a paper clip but the CEL light does not falsh, it just stays on. Could it be that I am using a obd2 to a obd1 ecu converter? Is there another method to check the CEL codes?
Also, when I did the conversion from obd2 to obd1 I didnt make any changes to the IACV or the Distributor. I read somewhere that I had to covert the 3 wire plug into a two? and that the distributor either I could keep it or change it for a obd1 distributor? Am I missing something else? Knock sensor?
You can run a car with a basemap, just not recommended to go boost crazy. I've driven all my boosted cars on basemaps to get me to where I need to go. Sounds like your basemap isn't setup right. Check the CEL and find out what code it's throwing. And then if there is a local tuner, just tow the car there. If your car doesn't even want to idle correctly let alone even drive.
Finally no more CEL light, seems the problem was the IACV wiring. I had to convert from 3 wires to 2. I will see how it runs now and post results later
1 - 9 of 9 Posts
