Fo Do' DX daily
Got this P06 from a guy on ebay selling tons of ecu's so i gave it a shot
i gave him my set up (y7 with bolt ons and a delta 272) and some other specs i wanted for the ecu and after 2 weeks it finally came and i put it in the car with the harness adapter and im getting a surging idle, and stumbling under accelleration
im wondering if maybe i got an ecu for 240cc injectors...which i have a set of im willing to try
Basemap for nice cam = fail get tuned.
Fo Do' DX daily
no i am now working on getting the 2 wire conversion done, but still so it runs extremely rough even with the IACV disconnected
iacv block off possible?
Ya you can block it and un hook the wires. You will get a code for the iac valve. You can then disable the iac in crome but it is buggy. If you want to ditch the iac you will have to look into a better rom editor like ectune, hondata, or neptune. Dont know if crome pro is any better with the iac ditch but free is buggy.
Don’t know what you are running now?????
Still basemaps = fail all day every day.
Fo Do' DX daily
i believe it is chrome
im running a y8 5 spd manifold with a y7 throttle body
i have the IACV holes plugged with epoxy but i think i might look for one from the junkyard to convert to 2 wire
just not sure what vehichle it has to be from
