1 - 14 of 14 Posts
ej2
Im just using this as a basemap but Im having troubles keeping this thing running...everytime I go to push the gas down it stalls out. Idk if its cause my tip in is to much, to little idk...
What is this way rich, low on timing. What is your set up.
moar infor please
What dose your wide band say you are at at idle and cruise?
Get the wide band in and adjust the hole map or the fuel multiplier to get things straight. Sounds like you are way rich.
Reactions: jeremy85
What code?
You have the half moon on the chip facing the ecu connectors?
1 - 14 of 14 Posts
