1 - 9 of 9 Posts
hello every body i have civic EK3 swap D16Z6 turbo engine block forge. i have a problem. i try exlpain you i sorry for my english i am french. after have rolled 40 minute about the engine goes out. At first I thought my battery, i changed them I tested my alternator it's god 14,5volt. Sometimes check engine lights but i can't check code engine because the engine goes out. I'm lost :( !!!
98 Civic CX-T on E85
few questions.
-does it just die or stall out??
-are you driving when this happens or is it parked and idling?
-do you have to wait for the power to come back on, or are you doing something to get the power back?
few questions.
question one: -i don't understand
two: -in driving engine not goes out but if stop in intersection the engine stop.
three: - sorry i don't untersstand.
86 MR2
If engine is swapped, is the wiring done properly? On my previous car it did that a lot, then after fixing wiring every once in awhile
is the idle fluxuating at all? if so, your idle air control valve IACV could not be catching the idle to let it sit and idle at a stop light when it warms up.
for the swap I kept my harness OBDII i just use harness conversion ODBII in OBDI i Corrected wiring for injector and map sensor.
1 - 9 of 9 Posts
