1 - 6 of 6 Posts
The car is a eg civic 92 to 95
Just wanted to know which fuse number under the dash controls the fuel pump? I am going to take out the fuel pump fuse and crank the car a few times to prime the oil feed line.
Which procedures are most common to follow when priming the oil feed line to the turbo?
Is it ok to pull the ecu fuse? The blue fuse in the engine bay passenger side?
Ahh this was posted about 2wks ago on here. But yea undo the drain hose and pop it into a bucket or something. Then disable the ecu via fuse, remove main rely, just jumper the starter to the battary etc...
Then crank the motor over a few times till oil comes out the drain. Then pour that oil back in tho motor. Top off. Hook everything up and starter up. Let it idle for 5mins or so and check for leaks, overheating, smoke. Then start tuning.
1 - 6 of 6 Posts
