1 - 12 of 12 Posts
I'm a newbie and would like to know the whole price start to finish on swapping a d15b8 to a z6
Never finishes (TWSS)
91 Civic SI hb/ 01 GSR
Z6 motor and tranny in the car and running can be dontle for cheap if you know what your doing. Any hwere from 200-600
95 civic coupe
Around here you can get a stock z6 for around 200-300 add 50-100 with trans. I wouldn't pay more than 500 for a swap
94 civic, 90 talon
Damn the prices are high in Az for some reason. I got a good deal on mine, as it came with a chassis around it lol. The swap was originally going for 700$ for just the swap. Which is a good price here.
Its cheap to just do the swap. But it does get a bit pricey when you start doing maintenance like timing belt, water pump, clutch, gaskets.
Thanks guys the cheapest motor I have found is 650 not included the tranny were would be a good place to order one from
They call me Awesome!
It depends on the condition and the source. Hmotorsonline has them for $7-800.
I've seen a full swap (trans, wiring harness, motor) all in perfect functioning condition go for $500 from an individual.
Also moved to the n00b section.
Buy a 94 si parts car for 500-700 dollars take parts needed send rest for scrap. I woudnt buy an imported dseries unless it was twin cam. We have way to many for cheap.
Around my area, swaps are around 550-650. Been watching for them because I have a bunk z6 in my Sol. That's just engine, trans maybe ecu and axles. Also, sitting on the garage floor not in a running car.
1 - 12 of 12 Posts
