1 - 2 of 2 Posts
I was wondering if I can use any other civic pressure plate on my 91 crx HF. my pressure plate is all fawk up. I already got the new clutch. I didnt think I'll need a pressure plate but after I took it, it was all mess up due to the previous owner driving it without any clutch left. I need to get this crx fix so I can park and fix my civic.
any d15 pressure plate will work, and if im not mistaken, any d16 should be the same way as well. If he drove on it with little clutch, I'd check the flywheel with a dye, or see if he glazed it really bad because of the rivets showing, if its bad, suggest replacing the flywheel as well, better to do it now than later.
1 - 2 of 2 Posts
