1 - 6 of 6 Posts
manifold
piping
intercooler
clamps
hose couplers
bov
wastegate if external
oil lines drain and supply
restrictor
oil psi guage
boost guage
vacuum lines
lots of fittings
radiator
3bar map sensor
OBDII conversion
chipped p28
rome pro
wideband
ostrich
rods
pistons
block work
head work
gasket set
bearing sets
head studs
injectors
fuel pump
axles
LSD
rims
slicks
clutch
springs
dremel
welder
grinder
sorry I got carried away. Oh yeah almost forgot...
30 cases of beer
Black Dynamite
Bizzar said:
manifold
piping
intercooler
clamps
hose couplers
bov
restrictor
oil psi guage
boost guage
vacuum lines
lots of fittings
radiator
3bar map sensor
OBDII conversion
chipped p28
rome pro
wideband
ostrich
rods
pistons
block work
head work
gasket set
bearing sets
head studs
injectors
fuel pump
axles
LSD
rims
slicks
clutch
springs
dremel
welder
grinder
30 cases of beer
Good GOD man
1 - 6 of 6 Posts
