1 - 4 of 4 Posts
W
I got my stuff layin around for boosting a z6, but my mate was wondering if he could turbo his 92-95 civic hatch dxi (in europe its called dxi) with a d15b2,
without making the dpfi - mpfi swap. So the main question is, can you turbo the civic dx d15b2 DPFI as it is, so just with an FMU & check valve?
you can however you will blow the motor really quick. two injectors wont cut it for the need of fuel under boost. swap to mpfi then upgrade to the turbo setup. good luck!
O
greddy kit will bolt right up. I think the e-manage will work with it as well if you get a newer kti with it instead of a used one.
thw D15b is capable if taking about 8psi after that your taking your chances from what I udnerstand so far. 8psi would get you abotu 165-175 wheel power with a fmic.
1 - 4 of 4 Posts
