1 - 18 of 18 Posts
i have a t3/t4. i have a 0.065 restrictor installed. it smokes under load alot and on idle a little bit. on the cold side of the turbo there is oil. is there anything i can do about this besides rebuilding it or buying a new one. is there a way to identify the problem 100%. thanks in advance
of oil pressure? or boost. it started smoking on idle
I can't read...
oil pressure. T-series turbos require only 30psi of oil pressure. i think hondas put out like 90psi at operating tempature.
i dont have a way of checking the oild pressure at the turbo. my oil return like looks like a j rather than a straight line, could that be the problem?
I can't read...
i don't think thats the problem. ive seen some wild bends in oils lines that never caused a problem.
so are you blowing oil through both sides then? hot and cold sides?
have you checked you oil drain line to make sure there are no obstructions?
its sucks man. i hate this trial and error BS. i went through the same shit with mine last year.
there are no kinks i will try another clear hose to see if it gets clogged up. yes both sides hot and cold
ok thats fine. but what caused its death? too much oil..
I can't read...
thats what happened on my t3...only i didn't use a restrictor. what kind of restrictor were you using?
insert user title here
domestic.
blown seals for sure. if its not a china turbo you might be able to send it to a shop that rebuilds turbos for either service or credit for another turbo
i just warmed it up and drove it and no smoke what so ever. this is after an oil change
Defender of the D
hmmm.. that does sound peculiar so it don't smoke now that u changed the oil?? keep us informed as to what the culprit ends up being..
trust me if i find anything out you guys will be the first to know
See above...
Guessing you just used the same oil as the last few changes? Did it start smoking within the time you changed the oil the last time?
this is its first oil change. castrol 1040.....
1 - 18 of 18 Posts
