88 CRX HF
Discussion Starter #1 (Edited by Moderator)
I have just finished reading this article about David Vizard's PolyQuad 4 valve Head design. (all 4 valves different sizes to promote Swirl).
http://www.motortecmagazine.net/the-future-of-4-valve-engines/
You will have to Google it, I don't have enough post to add links...
What are your thoughts on doing this to a D16a6 N/A ? By Using one oversize intake and one oversize exhaust valve...
MuthaFuckaUppa
2009 Civic Si Sedan
Colt Cams has their Tri-Flow cams that help promote swirl. I have thought about how this could be improved upon by using different sized valves. I wouldn't think that the exhaust valves would help much, but then again if you drain a bottle it empties faster if you swirl it.
Meat Popsicle
91 CRX Si
Have heard nothing but good things about those colt tri flow cams but damn they’re a little pricey at almost $400.
I wouldn’t spend a ton on head work. It’s an old head so it’s gonna need some maintenance work. New guides and seals, a good valve job, some quality aftermarket springs, and OEM retainers. You can do a mild port job yourself.
There’s honestly not a ton to be gained with oversized valves and a fancy port job. You’ll be much better off spending that money on a good cam.
MuthaFuckaUppa
2009 Civic Si Sedan
What I ment by different size valves is having one stock diameter intake valve and one over sized valve.
Meat Popsicle
91 CRX Si
I did the .5mm oversized valve thing on the head that Endyn built for me.
I wonder how much of a difference (if any) that it really made since the valve seats are the same size.
MuthaFuckaUppa
2009 Civic Si Sedan
Larger valves with a stock valve seat will not improve flow, it probably made less flow. Covering a hole with a bigger lid.
93 maybe 94 coupe
My 2 cents is that the early heads utilized a tumble rather than a swirl and that later y7 and y8 heads that utilize swirl theory and quench pads will see benefit from this that exceeds doing it on a tumble type head.
The intakes differ on the swirl vs tumble heads because promoting velocity is important to promoting swirl. A polyquad head with a cam that accentuated the flow disparities that create swirl will be at its best with a y8 intake and port work that maintains the ratio between the runners. (So dont hog both out like ur tryna make power on a z6 or a6)
That said i think while promoting swirl can make very good power its proven the big port z6/a6 setup utilizing tumble flows more and can make more peak power.
Reactions: CripTofer
MuthaFuckaUppa
2009 Civic Si Sedan
I would say your partially correct, there are 3-valve and 2-valve d-series for swirl before the y7 and y8.
I think one of the newer hybrids civics uses a 2-valve head.
I wish Honda would revisit CVCC, maybe with direct injection.
