UPDATE
Okay guys, I did a back to back comparison of the lightweight and stock flywheels. Every other variable was unchanged, other than the flywheel itself. Its a d16z6, 91 si cable tranny, Exedy stage 1 clutch, with the kevlar, sprung disk. Previously I had the exedy 12lb flywheel, now I have the stock 91 si flywheel which weighs approximately 18 # according to my scale.
I have to say, I really like the stock flywheel a lot better for daily driving. Things I immediately noticed: Smoother idle at lower rpm and when in neutral the revs don't drop as quick when revving. Driving: It takes a ton less work to take off smoothly. I used to feather the throttle a lot upon take-off and I was pretty good at taking off smoothly, but with the stock flywheel I barely have to feather at all. I just rev it up once and start letting the clutch out and it goes with no chatter. Shifting is very noticeably smoother going from one gear to the next while the clutch is disengaged and doesn't really jerk at all when going into the next gear when the clutch is released quickly. Rpms stay higher in-between shifts and I'm physically throwing the shifter slower now, which is going to mean good things when I'm racing and I am throwing it faster. One last thing, not that its a very important quality, but whatever, when on a totally flat road and at idle, I can let the clutch out slowly with no gas without the car stalling. Before that was impossible, at least some gas was necessary.
Acceleration is a BIT slower, but IMO it makes up for it by all the other previously mentioned qualities. Also, going up small hills does seem to be noticeably easier. I barely have to tip in the throttle to get over one. There are a TON of hills here so that's a great benefit to me. I won't be surprised if I pick up a little bit more mpg's now.
I think that's all. I don't think I'm gonna waste any money in the spring on putting a lightweight back on here.
I wish I would have intended to do this test and got some before and after datalogs to share, but I didn't, so sorry. You'll just have to take my word for it. :bigok:
