1 - 9 of 9 Posts
I have a zc sohc turbo stock internals planing on run 8-10 psi from a .60 .48ar turbo....I have 450cc injectors ,1:1 fuel regulator ,stock fuel pump.
I need to know if my stock pm6 ecu will be ok to run this set up without any problems or just chip the ecu with a turbo basemap that I found on ebay. I want to stay OBD-0 for now!!! just want to reach at least 180-220whp if its possible with this set up!!!
my set up:
zc sohc stock engine
60. 48ar turbo
log manifold
38mm wastegate
knock off bov
starion intercooler (fmic)
450cc injectors
fuel regulator
stock fuel pump
2.5 charge pipes
2.5 downpipe
stock pm6 ecu
adjustable cam gear
1992 cx, 1995 dx
Get a chipped ecu with turboedit. Post in engine mangement forum and xencron can help you with that.
I'm from PR and I don't know who tuned with turboedit. I have a tuner but he's good using the safc...I'm in a low budget so a pm6 ecu chipped and a dyno session....just adjusting the fuel and timing on the dizzy and the cam gear until I reach a safe afr
Certified O.G.
A Shitbox
I'm looking for a pm6 chipped ecu to buy...anyone????
If you have a PM6 i can chip it for you. Let me ask my supplier, see if he has any.
Edit: unless you wanna sack it up and go OBD1 :lol: ;)
1 - 9 of 9 Posts
