1 - 3 of 3 Posts
92 civic
Recently got a 92 dx
Previous owner overheated it bad (melted the timing belt and cover.
It has a zc block with a sohc head stamped pm3-4 and (9/4) in a circle next to it.
So what head gasket and what timing belt goes on it?
Google came up with too many different results. But what I've gathered is it needs a 107 tooth timing belt ( for a d16a6) and a head gasket for a d16y8. Is this correct?
2005 Honda Civic
From the research I did on google a D16a6 and the sohc ZC are basically the same engine with minor differences, try a timing belt from a 1990 civic Si, they came with the a6; but before starting the engine: rotate it by hand a few times to make sure you don't have the wrong belt to prevent nuking that engine even further.
92 civic
Thanks!
1 - 3 of 3 Posts
