Don't have the harness for the zc, I'm using the obd1 b7 harness. The b7 and z6 manifolds have this sensor on the drivers side of top of the back of the plenum, on the zc there is no sensor. Will it jot run correctly without this? Can't post pictures from photobuck as I have exceeded my bandwith, but you should get what sensor I am talking about
is it a white sensor? if so thats the iat sensor and you will have a code if not hooked up..
This what your talking about?
No, that one is there, its the one above it, it has a small vacuum line going to it and it has a black cylindrical cap on the top with an electrical connector on the bottom
oh ok like xile6 said its its your purge solenoid valve...ill try and post a pic of it....you dont need it,it will run fine with out it and no code will show up..
This one??
